9 years agoWindows 10 driver support for USB Blaster ?
In reviewing the drivers download page it appears there are NO drivers for Windows 10 for the USB based Blaster programmer cables. Is this really true ?
8 years agoI was able to install the drivers. You first have to disable driver signature enforcement. This is the sequence:
1 - Go to windows 10 settings and search for "advanced startup options" 2 - Under Advanced startup, hit "Restart now" 3 - After a moment, you'll get a "choose an option" screen - choose "Troubleshoot", then "Advanced options", then "Startup Settings" 4 - You'll get a screen telling you what you will be able to change and a single "Restart" button - press it. 5 - If your boot drive is BitLocker encrypted, you'll need to enter the recovery key (press return, enter the key in the text box then hit return again - it took me three goes to realize I had to hit return before I could enter they key !) 6 - You'll be given a menu of options, number 7 disables driver signature enforcement 7 - When the PC restarts, use Device manager to update the drivers - this time you'll get a warning about the signature, but they install fine. 8 - When you've finished, restart normally to re-enable signature enforcementBettlejuice
5 years agoBruv, thank you so much!
