9 years agoWindows 10 driver support for USB Blaster ?
In reviewing the drivers download page it appears there are NO drivers for Windows 10 for the USB based Blaster programmer cables. Is this really true ?
8 years agoHi All,
So I am doing development on two different PCs, using the same target and USB Blaster 2. One PC is win 7 the other win 10. The win 7 PC worked fine. Today I am using the Win 10 PC and have run into problems. When I first tried programming, Quartus didn't find the USB blaster. I checked device manager and the driver hadn't installed, so I did a driver update from device manager and pointed to the IntelFPGA_lite directory and the driver correctly installed and *appeared* to operate correctly. However, in-spite of going through the motions and "looking" like it is working, it is not programming my target board. My target board is using the MAX10M50SCE144. When I program, the CONF_DONE output goes tri-state for a short while, about a second, then lights again. I am using a new design that successfully compiles and an older design from the Win 7 PC that loads and runs OK under win 7 with the same USB blaster 2. Any thoughts? Thanks, Scott
