Will sending data from serial port to FPGA change the existing layout
- FakhrulA_altera
As we do not receive any response from you to the previous notification that we provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- FakhrulA_altera
Hi student8,
From my understanding, I think it is expected, while sending data from a serial port to an FPGA can impact timing, careful design considerations, proper clock domain crossing techniques, and appropriate buffering can help mitigate potential timing issues and ensure reliable communication between the serial device and the FPGA.
Fakhrul
- FvM
Do you get unexpected results while the parameter changes or continuously?
Trivial question, is the design fully constrained and meets timing?
- student8
Thank you for your reply.
Changing the parameter indeed made a difference. The final result is obtained by subtracting the measured circuit delay from this parameter. After the circuit was programmed, I thought the circuit delay would not change anymore. However, transmitting data via serial port actually caused a significant change in the measured circuit delay. I imposed very few restrictions or timing requirements, but I believed that the circuit would not change after programming
