student8
2 years agoWill sending data from serial port to FPGA change the existing layout
I designed a module that uses direct counting to measure signal delay through a circuit. One of the parameters is stored in a register and assigned using an external serial port. I used signal tap to ...
FvM
2 years agoDo you get unexpected results while the parameter changes or continuously?
Trivial question, is the design fully constrained and meets timing?
student8
2 years agoThank you for your reply.
Changing the parameter indeed made a difference. The final result is obtained by subtracting the measured circuit delay from this parameter. After the circuit was programmed, I thought the circuit delay would not change anymore. However, transmitting data via serial port actually caused a significant change in the measured circuit delay. I imposed very few restrictions or timing requirements, but I believed that the circuit would not change after programming
