9 years agoWidth of Slave id(4) must be min 5. Increase slave ID width or reduce connected maste
Hello, I have used the Arria 10 Soc design from rocketboard to which I am making few modifications. I am getting the following error in qsys when I exceed a particular number of connections.(to H...
9 years agoThank you sstrell for the reply.I have already done that.
I am using the F2SDRAM bridge in my design.The F2SDRAM bridge doesn't work if the conduit for emif is not enabled in HPS. Any other idea? As i go on increasing the number of slaves connected to HPS, the error is being modified to the below: Error: arria10_hps_f2sdram0_data: Width of Slave ID signals (4) must be atleast 7. Increase slave ID width or reduce widths for any connected AXI master
