15 years agoWhy TINY FEMALE JTAG header on DM6467T EVM for programming Altera CPLD?
This question is with respect to the Texas Instruments TMS320DM6467T EVM, called HD 1080p by Spectrum Digital. For in circuit programming of the Altera CPLD (EPM240GT100C5N), a 10 position header sh...
15 years agoYou have to make an 0.1" to 0.05" adapter, the pin assignment is identical to Altera as far as I see, but you should double check the correct position of pin 1 respectively VCC pin 4.
You should be able to program the MAX II device, debugging with MAX II is limited to Source & Probe tool and depending on the availiability of unused LEs in the design.
