Why is my nios custom instruction executing twice?
I see the VHDL code is totally correct. But I am wondering how you are using this C-code function: Can you please send to me more details about this function?
unsigned com_bus_simple(unsigned dataa, unsigned datab)
unsigned readdata;
readdata = (unsigned)ALT_CI_NIOS_FPGA_COM_0(dataa, datab);
return readdata;
Plus, Can you please share more details about the connection to/from NIOS II?
- JLiew7 years ago
To be honest, I have since rewritten a completely new custom instruction (now an extended one) with the express purpose to not do a double send, and now it is working.
I'll append both the old and new VHDL files and old and new examples of drivers that use it. Because, while I have a working instruction now, I still have no clue why the old one didn't work.
I've put them in a zip, because, apparently I can only add one file per post?
What would you want to know about the connection to and from the NIOS II? You mean how it is implemented in a FPGA entity?
Thank you
