13 years agoWhy has quartus stopped generating a time-limited sof file?
My Quartus license expires this month (2013.02) but appears to be valid at the moment. But all of a sudden, today, it will not generate a time-limited sof file because I'm using the Triple Speed Ethe...
13 years agoIf it happens again have a look at the assembler report and check if it says anything about why it didn't generate a .sof file. There is also a "generated files" report that could tell you if the file was generated somewhere else than in the usual folder (for whatever reason).
