RShal4
7 years agoWhy "fifoed avalon uart" was removed from web site ?
Hello, When using "uart" simple IP we encounter byte lost. We than moved to "fifoed avalon uart" ver 13.2 which was in alterawiki page. It solved our byte loss but only partly. When we use several...
KennyT_altera
7 years agoHi Ran,
How do you check the result? Is it with modelsim or signal tap?
The document that I found is https://www.intel.cn/content/dam/altera-www/global/zh_CN/pdfs/literature/hb/nios2/n2cpu_nii51010.pdf
Try to screenshot the result that you are seeing so that I can take a look the failure part.
