LChen23's avatar
LChen23
6 years ago
Why does Striatix 10 -3 speed 's Fmax of ROM restricted on 420Mhz, But it is not described in Timequest report?
Hi, expert
As Table 65. Memory Block Performance Specifications for Intel Stratix 10 Devices​ in Stratix 10 datasheet, the 'True dual port, all supported widths ' -E3V, performance is 420Mhz. But after timing analyzing in timequest , The report the Fmax summery is higher than 420Mhz , even could reach above 500Mhz .
so , my question is , which one should I trust, the 420Mhz in datasheet or 500Mhz+ in timequest report?
