RShal4's avatar
RShal4
7 years ago
Why BSP project ignores "disable generation" ?
I encounter this strange behaviour: I try to disable file generation of speciifc HAL driver file.
Yet, although I change it to "-" with "disable generation" and saves the settings
I verified that in xml there are addition lines:
    <IgnoredFileInfo>
        <componentName>altera_generic_quad_spi_controller</componentName>
        <fileName>altera_generic_quad_spi_controller.c</fileName>
    </IgnoredFileInfo>
Yet, on clicking generate bsp, it regenerate the file, and also remove the xml lines from setting, and in gui it also appears as enabled generation.
Any idea why it ignores the setting ?
I'm using quartus 15.1.
ran
  • FawazJ_Altera's avatar
    FawazJ_Altera
    May I know if this is related to Nios II software development or something else?
    If yes, which version are you using?
    • RShal4's avatar
      RShal4
      Is there any idea ?
      We really struggle with it for a long time now.
      • rshal2's avatar
        rshal2
        We need to use version 15.1 by customer request.
        Anyway, I did eventually solved the issue, by changing the driver tab from "default" to its number (I think 13.1 was the only other option except for default),
        After doing this change, it all worked as should be.
        Ranran
    • RShal4's avatar
      RShal4
      Yes, NIOS II /f
      IP: altera_nios2_qsys Version: 15.1
      Thanks for any suggestion,
