JGeor12
6 years agoWhile running the cyclone V ,the following routing problems are showing
Error (170143): Final fitting attempt was unsuccessful Info (170138): Failed to route the following 6 signal(s) Info (170139): Signal "lvdse_in[0]~input" Info (170139): Signal "lvdse_in[4]~in...
RichardT_altera
6 years agoHi,
You may need to modify your design to reduce resource/ the amount of logic or choose a larger device.
Fitter could not route the specified number of signals listed in the sub-message. This message can occur when the design uses a large number of device routing resources.
