Safila
4 years agoWhether Winbond Flash supported by Quartus Programmer?
We are using ArriaV 5AGXMB1G4F40 FPGA in our design.Earlier,the flash device used was “S25FL512”.Since the part is not available , we have replaced “W25Q512JVFIM”.
While...
YuanLi_S_Intel
4 years agoSeems like the setting on the flash is not correct. Just want to check if you are putting the correct command as per winbond datasheet? Also, have you probe the signal during configuration? We can get more clue there.
