8 years agoWhere to find SONET-SDH Compiler?
Hello, I am looking for SONET-SDH Compiler from Altera. As per Doc @ sonet/sdh compiler v2.4.0 release notes - altera (https://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&u...
8 years agoI'm not sure if the SONET/SDH compiler exists now, as the document you're referring to is quite old. For the latst SONET/SDH IPs :
https://www.altera.com/products/intellectual-property/ip/interface-protocols/tpw192s.html https://www.altera.com/products/intellectual-property/ip/interface-protocols/tpw48p.html The simulation models you seek may be present in these IP packages. You may need to contact your local Altera support to find out if the SONET/SDH simulation model is available.
