HuaYuLiang
4 years agowhere is the pin map of 10M02SCE144I7G? I need help!
I read the many data sheet and documents which include the MAX 10 but I can't find them.
such as in m10_datasheet-683794-666319.pdf, I can find signal's timing and max frequency...and JTAG Timing ...
HuaYuLiang
4 years agoThanks your reply!
I can't understand "we do not provide the pin map", why??
AqidAyman_Altera
4 years agoHi YuLiang,
I apologize I do not have the answer for that. Instead, we provide the pin list for 10M02SCE144 as attached.
In the Intel® MAX® 10 FPGA Design Guidelines, it mentioned the usage of Quartus Prime Pin Planner for I/O pin planning. You can refer to the below links:
1.6.1.2. Use the Intel® Quartus® Prime Pin Planner for I/O pin...
