Where is Quartus 13.1.4 patch 4.70r
Hello
Since it became necessary to replace the EPCS device with the EPCQ-A device,
I need quartus-13.1.4-4.70r patch file, which supports EPCQ-A.
Where can i find the link for this file?
Best regards.
Seem current issue is related to embedded config, I suggest you to close this ticket and open a new case thread for a right owner support. Let me know if there is any concern.
- SyafieqS
- on0308
I got it.
The added question is different from this one, so I will set up another thread.
Thank you for your support.
- on0308
Hi Intel Customer Support
Thank you for sending the file.
Thank you for helping me very much.
After applying the patch and in Convert Programming Files ... ,
I was able to confirm that the EPCQ-A device can be selected as the Configuration device and can be converted to a jic file.
But I have not solved everything yet.
Please tell me about the settings of Advanced options and saving the .cof file.
The settings are as follows.
Programming file type: JTAG Indirect Configuration File(.jic)
Configuration device: EPCQ128A
Mode: Active SerialAdvanced Options
checked Disable EPCS ID check
checked Disable AS mode CONF_DONE error checkProgram length count adjustment: 0
Post-chain bitstream pad bytes: default
Post-device bitstream pad bytes: default
Bitslice padding value: 1
QSPI Flash Single IO mode dummy clock: Unchangeable
QSPI Flash quad IO mode summy clock: UnchangeablePost-chain bitstream pad bytes: default
QSPI Flash Single IO mode dummy clock:Unchangeable
QSPI Flash quad IO mode summy clock: UnchangeableEven if I save the .cof file with Save Conversion Setup ..., the Advanced Option part is not listed,
Is it used incorrectly?Due to the above problem, I actually added the following to .cof file.
<cof>
<advanced_options>
<ignore_epcs_id_check>2</ignore_epcs_id_check>
<ignore_condone_check>2</ignore_condone_check>
<plc_adjustment>0</plc_adjustment>
<post_chain_bitstream_pad_bytes>-1</post_chain_bitstream_pad_bytes>
<post_device_bitstream_pad_bytes>-1</post_device_bitstream_pad_bytes>
<bitslice_pre_padding>1</bitslice_pre_padding>
</advanced_options></cof>
The above way of writing is supported to check "Disable EPCS ID check" and "Disable AS mode CONF_DONE error check"?
Also for reference, please tell me the values that can be set in <ignore_epcs_id_check> and <ignore_condone_check> and their meanings.
- SyafieqS
I sent an email with the patches attached for Win/Linux. Let me know if you are not able to retrieve them.
- on0308
Thank you for your reply.
I’m currently using version 13.1.4 build182(patch none).
I'm thinking of applying a patch to this, so I would like a patch file.
If the patch does not work, I will request Quartus with the patch.
Best regards.
- SyafieqS
Hi Sir,
Do you want the patch only or Quartus with patch?
- penggao
