HPark14
7 years agoWhen using Active Serial programming, Can MT25QU01G(SO 16 PIN) device compatible with ARRIA 10 GX 057 device????
My customer's prototype board has two configuration headers with arria 10 057 and MT25QU01G. One is Jtag header the other is Active Serial header. (I used USB Blaster made by terasic) Jtag configu...
HPark14
7 years agoHi Shafiq,
I think i have solved the problem. The schematic and MSEL pin setting is OK.
I tested 2 USB BLASTER cables ( terasic usb blasterP0320 ) and USB BLASTER II)
When I use the BLASTER II, active serial programming works well.
But when I use ther TERASIC USB BLASTER, I can't programming with silicon ID check error.
TERASIC SUPPORT team said that P0302 terasic usb blaster cannot support 1.8V ARRIA10 VCCPGM.
Thank you for your help.
