HPark14
7 years agoWhen using Active Serial programming, Can MT25QU01G(SO 16 PIN) device compatible with ARRIA 10 GX 057 device????
My customer's prototype board has two configuration headers with arria 10 057 and MT25QU01G. One is Jtag header the other is Active Serial header. (I used USB Blaster made by terasic) Jtag configu...
ShafiqY_Intel
7 years agoHi HPark14,
A10 GX is compatible with MT25QU01G flash device.
Did you select the correct AS configuration setting in Quartus? (Assignments --> Device --> Device and Pin Options --> Configuration --> Configuration Scheme)
How about your MSEL pin? Did you select 011 or 010 for AS configuration?
