17 years agoWhen Do MSEL pins become valid
A question, which In could not answer from the lit so far: Does it make any difference, if the MSEL pins are driven by a host to be free of the type of loading procedure? Will there be a power ...
17 years agoThanks so far, I intend to use a Cyclone II - but I do not think it makes a big difference.
So now that means, it is not possible to keep the option to switch to another configuration scheme? For some reasons I would like to use both processor based configuration and platform flash, since I want to adapt to two PCBs: The old board has no platform flash, while the new one has MCU anymore. But both boards should be equipped with the same header board carrying the cyclone environment.
