What's the proper DDR4 termination method in Intel FPGA?
Hi SYiwe,
Thank you for joining this Intel Community.
Please refer to my answer below:
- The address/command/clk should be pull-up to VTT after the last DDR4 SDRAM, what's the value of VTT? 1.2V or 0.6V? VTT in daughter card is 1.2V(VDD), but in some other example designs VTT=0.6V(VDD/2).
[Ans]: Terminate the DDR4 address, command, and control signals to VTT= 0.6V (VDD/2).
2. In daughter card, a resistor connects between CK0_T and CK0_C, but no resistor used to pull up CK0_T and CK0_C to VTT, should I add pull-up resistor for CK0_T and CK0_C?
[Ans]: No, no need to add resistor pull-up to VTT.
Hope this helps.
Aida
- SYiwe6 years ago
Thank you for your answer. But I still have some doubts.
CK0_T/CK0_C is differential clock output from FPGA to drive DDR4, not the reference clock input to FPGA.
According to the following figure in user guide, CK0_T/CK0_C should be pull-up to VTT.
So I would like to confirm the following conclusion with you: there's no need to add pull-up resistor for CK0_T/CK0_C, is that correct?
Thanks, regards.
