12 years agoWhat to do about excessive internal FPGA clock skew?
I'm using the Triple Speed Ethernet core and when I run TimeQuest I get the following timing constraints error. The timing requirements are not met by only a small margin but what got my attention is the rather high clock skew of 5 ns on the data arrival path: https://www.alteraforum.com/forum/attachment.php?attachmentid=8123 This is how the clock path looks like: https://www.alteraforum.com/forum/attachment.php?attachmentid=8122 Now it looks like that the clock mux is not using the dedicated clock routing network. What have I to do so that a clock mux instead of normal combinatorial logic gets instantiated? Currently my clock mux looks like this in VHDL:
tx_clk_to_the_tse_mac <= enet_clk_125mhz when('1' = eth_mode_from_the_tse_mac) else -- GbE Mode = 125MHz clock
enet_clk_2p5mhz when('1' = ena_10_from_the_tse_mac) else -- 10Mb Mode = 2.5MHz clock
enet_clk_25mhz; -- 100Mb Mode = 25MHz clock
Regards Martin4 Replies
I'm using the following optimized version now, which helped to reduce the clock jitter because the clock signal is routed on dedicated clock nets now:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8198 The clock mux is implemented like this now:blk_enet_clkctrl: block signal enet_clkctrl_cs : std_logic_vector(1 downto 0) := (others => '0'); begin enet_clkctrl_cs <= "10" when ('1' = eth_mode_from_the_tse_mac) else "11" when ('1' = ena_10_from_the_tse_mac) else "00"; inst_enet_clkctrl: component enet_clkctrl PORT MAP ( clkselect => enet_clkctrl_cs, inclk0x => CLKIN_25MHZ, inclk1x => '0', inclk2x => enet_clk_125mhz, inclk3x => enet_clk_2p5mhz, outclk => tx_clk_to_the_tse_mac ); end block; - Altera_Forum
What's the timing analisis result after opotimized?
With the optimized version I'm down to -0.076 ns Skew.
https://www.alteraforum.com/forum/attachment.php?attachmentid=8234 The path shown in the previous screenshot doesn't exist anymore because I cut the paths between the tx-, rx- and control-port-clocks as recommended by Altera. - Altera_Forum
--- Quote Start --- With the optimized version I'm down to -0.076 ns Skew. https://www.alteraforum.com/forum/attachment.php?attachmentid=8234 The path shown in the previous screenshot doesn't exist anymore because I cut the paths between the tx-, rx- and control-port-clocks as recommended by Altera. --- Quote End --- Thanks for you info!
