12 years agoWhat to do about excessive internal FPGA clock skew?
Hello, I'm using the Triple Speed Ethernet core and when I run TimeQuest I get the following timing constraints error. The timing requirements are not met by only a small margin but what g...
12 years ago --- Quote Start --- With the optimized version I'm down to -0.076 ns Skew. https://www.alteraforum.com/forum/attachment.php?attachmentid=8234 The path shown in the previous screenshot doesn't exist anymore because I cut the paths between the tx-, rx- and control-port-clocks as recommended by Altera. --- Quote End --- Thanks for you info!
