12 years agoWhat to do about excessive internal FPGA clock skew?
Hello, I'm using the Triple Speed Ethernet core and when I run TimeQuest I get the following timing constraints error. The timing requirements are not met by only a small margin but what g...
12 years agoI'm using the following optimized version now, which helped to reduce the clock jitter because the clock signal is routed on dedicated clock nets now:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8198 The clock mux is implemented like this now: blk_enet_clkctrl: block
signal
enet_clkctrl_cs
: std_logic_vector(1 downto 0) := (others => '0');
begin
enet_clkctrl_cs <= "10" when ('1' = eth_mode_from_the_tse_mac) else
"11" when ('1' = ena_10_from_the_tse_mac) else
"00";
inst_enet_clkctrl: component enet_clkctrl
PORT MAP
clkselect => enet_clkctrl_cs,
inclk0x => CLKIN_25MHZ,
inclk1x => '0',
inclk2x => enet_clk_125mhz,
inclk3x => enet_clk_2p5mhz,
outclk => tx_clk_to_the_tse_mac
end block;
