12 years agoWhat is Timing between nCEO and DCLK in a multi-device AS Configuration ?
Is there timing requirements between nCEO and DCLK when configuring two FPGA's from one EPCS device? The master device (the first FPGA configured) operates in an AS configuration mode and once ...
12 years ago --- Quote Start --- I have had some mystery with when I program the EPCS with my programming cable as to whether I need to remove the programming cable to allow the FPGA configuration to start. Sometimes I can leave it in. Sometimes I have to disconnect it (?). --- Quote End --- The AS header has nCONFIG and nCE pins. When AS programming starts, the USB-Blaster takes nCONFIG low and nCE high, which resets the FPGA, and tri-states the EPCS bus so the cable can drive the EPCS pins to program it. The USB-Blaster then leaves nCE high. Ideally it would drive nCE low at the end of programming, but that is not always what happens, eg., under Linux its different than under Windows. Cheers, Dave
