SJadh1
7 years agoWhat is rx_pma_iqtxrx_clkout signal ?
Hello, I am working on a design with transceiver. I would like to know what is rx_pma_iqtxrx_clkout signal ? What are the usage scenario's of rx_pma_iqtxrx_clkout signal ? Thanks & Regards, Sach...
Deshi_Intel
7 years agoHi Sachin Jadhav,
In general, below is the common cause of PLL loose lock issue.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/support/devices/pll/pll-loss-of-lock-checklist.pdf
Looks like your fPLL loose lock is highly caused by the instable or noisy rx_pma_iqrxtx_clkout as fPLL clock source.
May I know does fPLL loose lock in CDR LTD or LTR mode ? I presume LTR mode should still generate stable clockout and it shouldn't cause fPLL to loose lock, right ?
If everything works correctly then alternate debug suggestion is to constraint rx_pma_iqrxtx_clkout clock network to minimize the clock jitter. You can try to connect rx_pma_iqrxtx_clkout to "clock control block" IP and configure it to regional clock network instead of global clock network if possible.
dlim
SJadh1
7 years agoHello Dlim,
As of now I am manually configuring CDR in LTR mode and expect a stable rx_pma_iqrxtx_clkout.
What is the correct way of constraining rx_pma_iqrxtx_clkout signal for low jitter.
I will also try to add a clock control block before fPLL.
Is there any more surgical method to find the root cause ?
Thanks & Regards,
Sachin Jadhav
