SJadh1
7 years agoWhat is rx_pma_iqtxrx_clkout signal ?
Hello, I am working on a design with transceiver. I would like to know what is rx_pma_iqtxrx_clkout signal ? What are the usage scenario's of rx_pma_iqtxrx_clkout signal ? Thanks & Regards, Sach...
Deshi_Intel
7 years agoHi Sachin Jadhav,
May I know how do you monitor rx_is_lockedtodata signal ? Is it via probe on board or signal_tap ?
Can you share with me the screen shot of rx_is_lockedtodata signal ?
I do expect rx_is_lockedtodata signal to toggle high and low if there is no incoming data at all. 31.38MHz shouldn't be a valid result if rx_is_lockedtodata is toggling.
dlim
SJadh1
7 years agoHello Dlim,
I have routed rx_is_lockedtodata signal to sma connector(J7) on board. Which is connected to oscilloscope.
I see toggling behavior of rx_is_lockedtodata if CDR is set to AUTO(rx_set_lockedtoref, rx_set_lockedtodata -> 2'b00).
But if I set CDR to MANUAL mode (rx_set_lockedtoref, rx_set_lockedtodata -> 2'b01/2'b11) I see rx_is_lockedtodata is high and stable.
In this case I also see rx_pma_clkout giving 31.38Mhz.
Thanks & Regards,
Sachin Jadhav
