What does _CH[B,T]p mean?
Hi Everyone!
I have a question about pin name.
In pdf document "Intel Arria 10 GX, GT, and SX Device Family Pin Connection Guidelines"
Explained..
RREF_[T,B][L,R] - . . . top (T) side or bottom (B) side and left (L) side or right
(R) side of the device.
So, my question is below...
1. REFCLK_GXB[L1,R4] [C,D,E,F,G,H,I,J]_CH[B,T]n
What does CH mean?
What does [B,T] mean? Is this a Bottom or Top?
2. VREFB[[2][A,F,G,H,I,J,K, L], [3][A, B,C,D,E,F,G, H]]N0
What does N0 mean?
Thanks!
Hi there,
For1.
CH is Channal, b t is bottom and top.
For2.
There is no meaning for N0. You don’t need to care about it~
WZ
- MADesigner
Right.
So after I pick one that is most convenient, do I connect the other ground or leave floating?
- MADesigner
I know this is from 3 years ago, but....
Which clock do I choose for the REF_CLK_GXBL?? for the transceiver in that same IO Bank, B or T? Do I connect both to the same clock source? Do I only connect one and the other to ground? Does it matter which one I choose?
Why does the FPGA that has all its connections in a ball grid array on th bottom have a clock input labeled as Top or Bottom?
- sstrell
Top or bottom edge of the device.
- WZ2
Hi there,
For1.
For2.
WZ
- schlee68
To WZ2
Thanks!
