What do two yellow and two green blinking LEDs on the Intel N3000 PAC mean?
- 4 years ago
Hi Anup,
Thanks for your help.
I will issue this info immediately to the related team for further procedure.
It might take approximately 3-4 days due to the weekend.
What I can help now, is highlighting your urgency on this case
Will get back to you as soon as possible.
WeiChuan_C_Intel
For reference, the extra N3000-N card on an identical Dell PowerEdge R720 (same OS/kernel image) works fine.
The `fpgainfo bmc` command shows:
Board Management Controller, MAX10 NIOS FW version D.2.1.24
Board Management Controller, MAX10 Build version D.2.0.7
//****** BMC SENSORS ******//
Object Id : 0xF100000
PCIe s:b:d.f : 0000:08:00.0
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
Bitstream Id : 0x23000010000000
Bitstream Version : 0.2.3
Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846
( 1) Board Power : 45.06 Watts
( 2) 12V Backplane Current : 2.04 Amps
( 3) 12V Backplane Voltage : 11.95 Volts
( 4) 1.2V Voltage : 1.20 Volts
( 6) 1.8V Voltage : 1.82 Volts
(10) FPGA Core Voltage : 0.90 Volts
(11) FPGA Core Current : 5.95 Amps
(12) FPGA Core Temperature : 45.00 Celsius
(13) Board Temperature : 31.00 Celsius
(14) QSFP A Voltage : N/A
(15) QSFP A Temperature : N/A
(24) 12V AUX Current : 1.73 Amps
(25) 12V AUX Voltage : 11.96 Volts
(37) QSFP B Voltage : N/A
(38) QSFP B Temperature : N/A
(44) Retimer A Core Temperature : 50.00 Celsius
(45) Retimer A Serdes Temperature : 51.00 Celsius
(46) Retimer B Core Temperature : 51.50 Celsius
(47) Retimer B Serdes Temperature : 52.00 Celsius
Hi Anup,
WeiChuan_C_Intel
- Wincent_Altera4 years ago
Hi Anup,
Close this case as already resolves this issue in another platform.
Feel free to reach out again to us if you have any other queries in the future.
Wish you have a nice day ahead.
WeiChuan_C_Intel
