Anup_Agarwal
4 years agoWhat do two yellow and two green blinking LEDs on the Intel N3000 PAC mean?
I was trying to install Intel N3000 FPGA PAC on the Supermicro 2029GP-TR server. The FPGA shows 2 yellow and 2 green leds blinking. This behaviour is not described in the manual. The FPGA does not sh...
- 4 years ago
Hi Anup,
Thanks for your help.
I will issue this info immediately to the related team for further procedure.
It might take approximately 3-4 days due to the weekend.
What I can help now, is highlighting your urgency on this case
Will get back to you as soon as possible.
WeiChuan_C_Intel
Wincent_Altera
4 years agoHi,
Not sure which LED you mention is blinking.
For detail, you may refer to Intel FPGA Programmable Acceleration Card N3000 DataSheet, page 17/31.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ds/ds-pac-n3000.pdf
- Table 8. does mention the LED behavior.
- For Connectivity LED
- Yellow means link up with link speed of 10G
- While Green means link up with speed of 25G
Do you see N3000 card enumerate in PCIe Bus ?
- I suggest you can try to remove the card from slot and check if the slot and edge connector is clean
- Please ensure that the server is running at maximum fan speed
Let me know if this helps.
WeiChuan_C_Intel
