15 years agoWeb Server example
Hi, With reference to the web server example available in Altera Wiki http://www.alterawiki.com/wiki/web_server_with_ajax_progress_bar, I tested the example project and it works fine ( it was t...
15 years agoHas the file been overwritten when you re-generated your BSP? You would need to disable the auto-generation for "altera_ro_zipfs.c" in the bsp editor or it will trash your changes..
Otherwise i'm not really sure what i advise i can give, I'm by no means an expert on the Altera Software. Sorry i cant help more at the minute. Our goal is similar to remove the flash so perhaps i'll run into the same problem. Cheers Tim
