15 years agoWeb Server example
Hi, With reference to the web server example available in Altera Wiki http://www.alterawiki.com/wiki/web_server_with_ajax_progress_bar, I tested the example project and it works fine ( it was t...
15 years agohello Drinkyfish,
With reference to your solution for running webserver using epcs controller, the solution was tested by me using the same development board that already has a flash memory, and it works somehow. However when I test the solution on another development board "that does not has a flash memory on it", I got the following error (picture attached) From the picture, I can see that the webserver is running however the web pages were not uploaded! Any idea or advise? Best Regards'
