15 years ago
Web Server example
With reference to the web server example available in Altera Wiki http://www.alterawiki.com/wiki/web_server_with_ajax_progress_bar, I tested the example project and it works fine ( it was tested on FPGA Cyclone III with flash memory on the development kit.
I want to run the web server project on a kit that does not have flash memory, instead I used epcs controller to upload the ro_zipfs.zip file (of course I modified the base address of epcs controller accordingly) ......what I got on the web browser is: Can't open the 404 File Not Found error page. Have you programmed the filing system into flash?
Is it possible to use epcs controller instead of flash memory,if yes, why am I receiving the above error message?
