12 years agoweb server demo program execution using De2 115 board
hi
I am trying to run web server demo program on cyclone Iv E DE2 115 kit. can someone give me detailed steps on how to do the same?? Thanking in advance veer7 Replies
--- Quote Start --- hi I am trying to run web server demo program on cyclone Iv E DE2 115 kit. can someone give me detailed steps on how to do the same?? Thanking in advance veer --- Quote End --- I hope you are able to select Ethernet Mode MII/RGMII by selecting JP1 or JP2 ETHERNET0 and ETHERNET1. If you get any error, please follows the below link. http://www.alteraforum.com/forum/showthread.php?t=27115 - Altera_Forum
Thanks to kkr. I followed the steps and i am getting the following error when i try to build my project.
make -s all includes Creating system.h... Jan 28, 2014 12:51:46 PM - (SEVERE) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.NumberFormatException: empty String make[1]: *** [system_description/../obj/system.h-t] Error 1 make: *** [system_project] Error 2 Build completed in 48.531 seconds Anyone who has resolved this problem plz reply.... thnx in advance........ - Altera_Forum
--- Quote Start --- Thanks to kkr. I followed the steps and i am getting the following error when i try to build my project. make -s all includes Creating system.h... Jan 28, 2014 12:51:46 PM - (SEVERE) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.NumberFormatException: empty String make[1]: *** [system_description/../obj/system.h-t] Error 1 make: *** [system_project] Error 2 Build completed in 48.531 seconds Anyone who has resolved this problem plz reply.... thnx in advance........ --- Quote End --- Hi Veer, You are welcome. It looks like you have Java path error. Please check your java environment path and try to fix it. I hope you are using NIOS II Command Shell instead NIOS II BST. - Altera_Forum
Hi KKR,
We are making use of NIOS-II IDE , not NIOS_II Command shell. Would that be a problem? Please reply me the steps to fix that JAVA path ERROR. - Altera_Forum
--- Quote Start --- Hi KKR, We are making use of NIOS-II IDE , not NIOS_II Command shell. Would that be a problem? Please reply me the steps to fix that JAVA path ERROR. --- Quote End --- Hi veer, Try to use NIOS II Command Shell, as you already have commands in one of previous thread. I finished few months back on same DE2-115 board, but with MII inference. Hope, it will be the same for you. - Altera_Forum
Hi kkr,
Hey i was able to run the web server demo program thnk u very much......... - Altera_Forum
--- Quote Start --- Hi kkr, Hey i was able to run the web server demo program thnk u very much......... --- Quote End --- That's great. You are welcome.
