PGigl
7 years agoWe are getting the following message "Design requires adding a large amount of routing delay".
We are getting the following message "Design requires adding a large amount of routing delay". We have examined the paths with this issue and they are clock crossings. We have put in false paths on t...
KhaiChein_Y_Intel
7 years agoHi,
May I know if you have any updates?
- PGigl7 years ago
The paths in question where crossing clock domains. The clocks are derived from a single PLL but are asynchronous (25 Mhz and 8 Mhz) but the tools were treating them as synchronous, and trying to meet a hold because of that. A timing constraint was added to make the clocks asynchronous, and that solved the issue.
