16 years agoWarnings of uart_receiver to solve
The receiver of UART contains input pins like rxd,clk. and outpu pins like RDR whose value depend on the RXD.Now I got two warnings.1.Warning: Output pins(all) are stuck at VCC or GND,2.Warning: Design contains 5(all) input pin(s) that do not drive logic. As you may know that the output of the design completely depends on the input rxd which I didn't assign. Then I looked into the map viewer only finding there are no connections amount the pins.Help me.
your program may stuck at some point that lead to no reset or no evaluate to your signal . you may check your program carefully for logic error.
Do you actually intend a FF, that can never be reset, execpt on power-on?
I've got the similar warning:
Warning: Reduced register "inst31" with stuck data_in port to stuck value VCC trying to compile a part of y design (Problem.jpg). I've found solution using buffer - carry (Sollution.jpg) - Altera_Forum
How to deal with these kinds of warnings??
Warning: Output pins are stuck at VCC or GND Warning (13410): Pin "RDR[0]" is stuck at GND Warning (13410): Pin "RDR[1]" is stuck at GND Warning (13410): Pin "RDR[2]" is stuck at GND Warning (13410): Pin "RDR[3]" is stuck at GND Warning (13410): Pin "RDR[4]" is stuck at GND Warning (13410): Pin "RDR[5]" is stuck at GND Warning (13410): Pin "RDR[6]" is stuck at GND Warning (13410): Pin "RDR[7]" is stuck at GND Warning (13410): Pin "SETRDRF" is stuck at GND Warning (13410): Pin "WRONG" is stuck at GND Warning: Design contains 5 input pin(s) that do not drive logic Warning (15610): No output dependent on input pin "bclkX8" Warning (15610): No output dependent on input pin "RDRF" Warning (15610): No output dependent on input pin "sysclk" Warning (15610): No output dependent on input pin "RST_B" Warning (15610): No output dependent on input pin "RxD" Warning: No paths found for timing analysis
