15 years agoWarning: (vsim-3473)
Hi dear all,
Can somebody help me? I have little question. The folowing net list compiles without error but simulation gives worning. Plise help me!!! --********************************************************* library ieee; use ieee.std_logic_1164.all; entity basic is port(input : in bit; output: out bit); end basic; architecture B1 of basic is begin output <= not input; end B1; --********************************************************* --********************************************************* library ieee; use ieee.std_logic_1164.all; entity second is end second; architecture B2 of second is component lebel is port (in_1 : in bit; out_1 : out bit); end component; signal in_1, out_1 :bit; begin a1: lebel port map(in_1, out_1); end B2; --********************************************************* --********************************************************* library ieee; use ieee.std_logic_1164.all; configuration config of second is for B2 for a1: lebel use entity work.basic(B1) port map (in_1, out_1); end for; end for; end config; --********************************************************* --********************************************************* that is the Worning message-** Warning: (vsim-3473) Component instance "a1 : lebel" is not bound.3 Replies
- r_m_n
Hey,
Have you solved this? I am running into an identical problem and I don't know how to fix this.
Cheers!
sorry but can you more detaily write how can it i do?
you havent included the source code for the lebel entity
