Warning: (vsim-3473) Component instance "spislave_0 : SPIPhy" is not bound.
Hi everyone,
I'm trying to simulate SPI at Modelsim 10.5B.
I've used Avalon ST SPI core to generate the component, and then I wrote the testbench(TB).
But when I'm trying to simulate the TB, then I get this warning: "Warning: (vsim-3473) Component instance "spislave_0 : SPIPhy" is not bound."
As I understand, some library is missing.
The question is : What library is missing?
- RichardT_altera
Since there is no feedback on the thread from you, I shall set this thread to close pending. If you still need further assistance, you are welcome to reopen this thread within 20days or open a new thread, someone will be right with you.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 9 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
- RichardT_altera
You can try to simulate using the nativelink feature in Quartus Prime as all the library preparation are generated automatically. Link below:
Though it is not supported in Quartus Prime Pro Edition.
