15 years agowarning on ALT_ASMI_Parallel_Interface
I have a Cyclone III EP3C5 design that uses an EPCS4 device in AS mode for remote system update.
I add the ALT_ASMI_Parallel_Interface for writing and reading EPCS4,but quartus gives Warning: Following 1 pins must use external clamping diodes. I found this pin: cycloneii_asmiblock3~ALTERA_DATA0. it's not in my port list, i guess it is automatic assigned by quartus when using ALT_ASMI_Parallel_Interface. does anyone know how to deal with this? Thanks a lot in advance1 Reply
The warning is about configuration pin DAT0. I would however primarly follow the device manual suggestions that recommend a series termination at the EPCS device but no clamping diode.
