HAlex's avatar
HAlex
4 years ago
Warning (169180): Following 4 pins must use external clamping diodes.
Hello I am using EP4CGX150CF23C8 connected to EPCQ128ASI16N flash at ASx1 mode. Serial flash should store 2 images (factory and application) and should work at remote update mode. When I setup...
  • hareesh's avatar
    hareesh
    4 years ago
    Hi Alex Halfin,
    if you see in fig. 8 - 28 it has two headers. one for JTAG mode header and another one AS mode header. if you following combine the AS configuration scheme with the JTAG-based configuration then follow fig. 8-28 schematic or following programming of a serial configuration device with the JTAG interface then AS mode header and those diodes are not required.
    Cyclone IV Device Handbook pdf link attaching here
    https://www.ee.ryerson.ca/~courses/ee8205/Data-Sheets/sopc/cyclone4-handbook.pdf
    Thank you
    Hareesh.
