RStew7
6 years agoWant to dual boot without remote or local capabilities, just two images jumper configurable.
I've been trying to build a dual boot image for a 10M08DAF484C8G but I can't get it to compile or create an image with two images for CONFIG_SEL selection. Is there a way to do it without IP or remo...
YuanLi_S_Intel
6 years agoHi Richard,
You will need to write your own state machine to do so if you don't want to use IP. I would recommend to use IP as it is already there. May i know what do you meant by cannot get it compiled?
Are you having problem in quartus design compilation with this IP?
Thank YOu
- RStew76 years ago
Hi, Thank you for contacting me. I’m using Quartus Prime Ver 17.1.0 Build 590 Lite edition. I’m using the Altera Dual Configuration in the IP library. The configuration mode is set to Dual configuration. //instantiation of the required IP for dual boot. dual_boot u0 ( .clk (LOW_B_CLK_IN) // clk.clk ,.nreset (reset_n) // nreset.reset_n // ,.avmm_rcv_address (<connected-to-avmm_rcv_address>) // avalon.address // ,.avmm_rcv_read (<connected-to-avmm_rcv_read>) // .read // ,.avmm_rcv_writedata (<connected-to-avmm_rcv_writedata>) // .writedata // ,.avmm_rcv_write (<connected-to-avmm_rcv_write>) // .write // ,.avmm_rcv_readdata (<connected-to-avmm_rcv_readdata>) // .readdata ); Is instantiated. The error is: Error (169130): Configuration mode specified as Remote but remote update block is not found in design. Thanx, Rich
