16 years agowaiting for clock ?!
Hello, I am using signal-tap to investigate a problem. But currently the problem is signalTap itself. I have a trigger clock (100 Mhz), which I am sure its running, otherwise nothing would run...
16 years ago --- Quote Start --- Hello, I am using signal-tap to investigate a problem. But currently the problem is signalTap itself. I have a trigger clock (100 Mhz), which I am sure its running, otherwise nothing would run on the FPGA but a PC, which is connected to that FPGA board is receiving the data..this means that the clock must run The strange thing is that Signal-Tap displays that he is waiting for the clock. So this means that S.T. doesnt see any clock transitionon the trigger clock I am only using signals from the presynthesis Does anybody else here has already encountered the same kind of problem ? Could it be a JTAG connection problem ? But flashing the FPGA is working fine and S.T. doesn't report any bad JTAG connection --- Quote End --- Hi, did you get any warning during compilation that your clock node isn't found ? When you open the stp-file is the clock node dispalyed in red colour ? Kind regards GPK
