16 years agoVREF pin and EPCS and OCT questions
1. In the Cyclone iii's Pin Guidelines, it says" the VREF pins are available as user I/O pins. All of the VREF pins within a bank are shorted together." Does it mean that the four VREF pins in a bank...
16 years ago1. no, they are individual I/O, not tied together. you can use the pin planner to assign your design's ports to the VREF pins and QII will use that as a user I/O
2. take a look at the EPCS Controller 3. go to Assignments > Settings, create a new assignment for your pin and select Output Termination as the Assignment Name, and select a value
