15 years agoVoltage range added on I/Os
the output voltage of MAX197(AD) is 5V,can it be added directly to IOs of EP2C8Q208?
thank you!2 Replies
thanks.I have some pcs of 74LVC4245 at hand.
Digital inputs of MAX197 have a TTL specification and can be driven by a 3.3V supplied FPGA output, but data from MAX197 to FPGA need a level conversion. Because the data bus is birectional, either 5V tolerant bidirectional buffer (e.g. 74LVC245), a true level converting buffer, or at least series resistors and PCI clamp diodes at the FPGA should be used.
