12 years agovoltage a-b-c to alpha beta transformation
i have done a programme of voltage transformation from a-b-c to alpha beta. input voltage of each phase will be 10 volt. so i take three input pin in schematic ......but which three pin i assign in ...
12 years ago --- Quote Start --- To process analog voltages, you need a device with analog inputs and outputs. If you are processing analog signals in FPGA, external ADC and DAC are required. Which hardware (e.g. development board, additional analog interface board) do you have? Where do you want to connect the 10V analog signals? --- Quote End --- Thanks for giving me the valuable suggestions.....the which three input pin which i assign in dac programming for input....as example i assign the output pin as 122 and 124..
