Virtual Pin Assignments -- does Value=Off/On imply logic 0/1 for pin?
virtual pin assignment removes a top entity port pint from the actual port list.
You can assign an initial value to the pin to achieve what you want.
- Steve-Mowbray-ENL2 years ago
Hi FvM -- ok that makes sense and more specifically implies SV 2009 or later (for default port values) -- I will try
- sstrell2 years ago
No. As stated, setting a top-level signal with the VIRTUAL_PIN assignment ON means that that signal will be routed to a logic "stub" in the FPGA fabric instead of to an I/O pin. This is usually used if you don't yet know what specific I/O pin you want to use, but you don't want the compiler to optimize away the signal because it's not connected to anything. There's even a quick video on this! https://www.youtube.com/watch?v=QET0lC-jdAQ
Hi sstrell -- thanks I watched that video before posting but did not pick up what the port logic value used by the compiled design when running would be -- my questions arising are:
- does default port value method suggested by FvM put a fixed know value for the virtual pin port signal?
- what happens if you set the virtual pin value to OFF instead of ON?
1) Value will be low at configuration on most devices as it is with all other signals (presuming you are talking about an input, not an output, here). On Stratix 10, you can initialize signals to high on configuration.
2) Not much. You're basically saying the signal must be attached to a pin location, and if it's not, it could get optimized away.
