VIP Suite Scaler; Bad Status Value and Strange Mixer Behaviour
Hello All,
I'm having trouble with my scaler. I'm using the SoPC builder in Quartus 9.1: RGB(4:4:4) Progressive SXGA (1280x1024) 60Hz Parrallel TTL -> CVI -> Scaler (Nearest N.) -> FB (DDR2 w/Pipeline Bridge) -> Mixer -> CVO -> SVGA 24bit Parallel TTL. The background layer for the Mixer is a Test Pattern Generator. The Scaler and Mixer have control ports enabled which are being controlled by a Nios executing from internal M9K RAM. The whole path is clocked with the pixel clock (110MHz) of the incoming video, but I run it through a PLL first (1:1) for some jitter correction - is this a good idea? (seems to look ok.) I have had two problems: 1) on some builds the mixer appear to work, but the scaler status register reads 0xffff ffff. if i remove the control port from the scaler, the system works (mixer controllable).2) on some builds i can't set the go bit of the mixer, this will typically be accompanied by a status read of 0xffff ffff from the scaler status register. Note that without control (i.e. a mixer) the path works well; so I'm assuming that there is no buffer overflow from the CVI and that the fb is functional. I find the scaler register read disturbing; this makes me think that I'm not reading valid memory and that the scaler is not getting the GO command either. To that end I checked the memory address allocation, and I'm using: 0x0000 0000 - 0x01ff ffff - DDR2 0x0200 0000 - 0x03ff ffff - pipeline bridge 0x0400 0000 - everything else Also note that when I use the SoPC builder command 'automatically assign base addresses' it tries to put 'everything else' starting at 0x0, i.e. over the top of the DDR2 range. Is that ok? I'd have thought that DDR2 is only accessible through the pipeline bridge... but I wouldn't be suprised... I'd love to hear back from anyone with any perspective, my head is getting very sore and there's now a crack in the wall where I've been banging it... Thanks in advance, Brent.
Let me know if you want me to look into anything further.
Jake - Altera_Forum
The problem appears to be resolved by adding timing constraints to the system.
I've still got an issue which causes the video to become 'skew'; it seems that not enough pixels are being clocked out (of one of the vip blocks, not sure which) so what should be a vertical line becomes diagonal left, etc. Strangely enough, no timing constraints were needed in Quartus 9.0 to achieve the same result - guess there are considerable differences between 9.0 and 9.1. Many thanks to Jake for going the extra mile! Guru status well deserved. - Altera_Forum
Looks like timing is an issue. Yesterday using the 'Classic Timing Analysis Wizard' I managed to get the video path working again without flicker or failure and even hooked up control to the CVO - it still doesn't look as good as the one I compiled under Quartus 9.0, but there could be other factors at play.
I'll do the coursework you've prescribed and try it again with TimeQuest. Thanks again, Brent. - Altera_Forum
TimeQuest is extremely powerful. However it does have a learning curve associated with it.
Make this page your best friend: http://www.altera.com/support/software/timequest/sof-qts-timequest.html I recommend this course: http://www.altera.com/education/training/courses/odsw1115 Jake - Altera_Forum
To be completely honest, I'm not sure how to! It wasn't a problem when I was developing in Quartus 9.0 - so I never bothered to learn. I just checked that my system clocks were below the Fmax specified in the compilation report. I've just fired up TimeQuest and I'm going to teach myself - any tips?
Cheers, Brent. - Altera_Forum
You know one thing I never asked was if you had your timing properly constrained and were meeting timing requirements.
Jake - Altera_Forum
Hey Jakob,
I’ve just finished upgrading to 9.1 sp1 and I wanted to re-try a few things before I send my project through; my strong feeling is that Quartus, and especially the jump from 9.0 to 9.1 has caused this problem. I actually have a 2nd pc of similar spec and I’ve put a fresh load of quartus 9.1 on it, and I’ve found that if each PC compiles the same software source (simple vip system, with no nios control), the .sof built on the 2nd machine doesn’t work, but the .sof built on machine 1 does. Hopefully sp1 corrects a few instabilities. Once I feel I've got a stable set of tools I’m going to cut the project back and try to manipulate each of the VIP blocks piece wise until I can identify the one that is giving me grief. I'll probably send you my project at this stage; there is nothing proprietary in it fortunately - I'm not at that stage yet, I am yet to achieve a starting point for our application. I'll work through the day here in Sydney and there'll probably be something in your inbox when you wake up in the morning. Cheers, Brent. - Altera_Forum
Actually I don't know if you're in a position to do this but if you can send me your project (and software), I think I can duplicate it on a Stratix II board I've got here. Then I could better find out what's giving you grief.
Jake - Altera_Forum
FYI, Mixer input one is a test pattern generator, input two is from the video input path.
