12 years agoVIP - Clocked Video Output - No Vsync Signal (Help Please)
Hi I'm new to the Altera's Video/Image IP suite so I set up a simple system in Qsys, Quartus v13.1: Test Pattern Gen (TPG) -> Clocked Video Output (CVO). My goal was to display basic color bar ...
12 years agoOkay I've tracked down the root cause. There seems to be a bug in the Qsys tool. Even though I set the resolution to 1024x768 in Test Pattern Gen GUI, the resolution was set as 1024x480 in .qsys file. See the section below. After I manually updated the file in a text editor (i.e. changed TPG_MAX_HEIGHT from 480 to 768) and recompiled the project, my setup TPG->CVO works fine now.
I’m not sure why Qsys doesn’t correctly generate the system file. We shouldn't have to manually alter the .qsys file. I sent an email to Altera FAE. From .qsys File: ============ <module kind="alt_vip_tpg" version="13.1" enabled="1" name="vip_tpg_vga_out"> <parameter name="AUTO_DEVICE_FAMILY" value="Cyclone V" /> <parameter name="CHANNELS_IN_PAR" value="3" /> <parameter name="CTRL_INTERFACE_DEPTH" value="10" /> <parameter name="PARAMETERISATION"><![CDATA[<testPatternGeneratorParams><TPG_NAME>MyPatternGenerator</TPG_NAME><TPG_RUNTIME_CONTROL>0 </TPG_RUNTIME_CONTROL><TPG_BPS>8</TPG_BPS><TPG_MAX_WIDTH>1024</TPG_MAX_WIDTH><tpg_max_height>480</tpg_max_height…</parameter> </module>
