16 years ago[VHDL]How to read data stocked in 1 ROM (created with Quartus)
I work at a little program with VHDL. In my program, i created a ROM with Quartus "MegaWizard Plug-in Manager" and which is already filled with a .mif file. And then in my VHDL program, I'd like to have access to this data and use them for my calculation. My component : component rom_qpsk PORT ( address : IN STD_LOGIC_VECTOR (4 DOWNTO 0); clock : IN STD_LOGIC ; q : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) ); end component; For example, if i want to know the value stocked in address "00000", how can i do ? Thank you very much for your responses !!!! :)1 Reply
you need to provide a clock to your clock port, provide the address "00000" to the address port, and check the q output after a number clock cycles from when you provide the desired address. the number of clock cycles is equal to your latency, or pipelining of the ROM
