14 years agoVHDL works only with xilinx
I wrote a vhdl code that interface with a module through SPI communication protocol my code was done in FSM with next state logic, it worked perfectly with my spartan 3AN board but when i try it on ALTERA DE0-nano baord it didnt work at all although its pure VHDL what i understand is that vhdl is suitable for any FPGA, so can any body please explain to me whats happinig.another thing if i didnt use global reset for the code does it make difference ?24 Replies
What specifically doesn't work?
it doesnt work at all dead
Maybe You've connected reset wrongly? Isn't the module synthesized out?
every thing is connected in the good way what i want to know why the vhdl code works with xilinx only is there a reason ? is there a special coding style for altera ?
No, only dumb mistakes left by designer. Something is bad with Your design.
so in this case why it works with xilinx ?
Because Xilinx synthesizer is buggy too :)
I'd offer to attach SignalTap and watch what's happening to the FSM and all the signals. Upload the module code to pastebin if You can, so someone could revise it. - Altera_Forum
ok if it works with xilinx because xilinx synthesizer is buggy:confused: then why quartus synthesizer dont give me even one single error?
It probably gives You a warning. Maybe something synthesized out..? Post a module source code.
