15 years ago
VHDL to schematic
hi
hope if any one knows how to convert VHDL codes to schematic drawing, can this be done by altera software, or there is different software should be used
thank you so much
    thank u for the reply, i downloaded the Quartus web edition, it does not support RTL as it is limited software, i am trying to write a code for T-bird ford tail lights, i did write the program , have you ever coem across such a program
    what did you simulate with?
    If it was a post synthesis simulation, it will have encoded your states into binary.
    thank you once again for the reply, it is highly apprecaited, i will try to down load Quartus web edition and see if it works,,,
    just have another question about a program i alreday wrote in VHDL , when i simulated the program , in the wave form , i can not see the names of my states, the wave is correct but instaed of writing the names of the states it deals with them like numbers 0,1, 2, 3, 4, 5, 6, 7, i will be so thankful to you for the help
    I'm pretty sure Max+Plus 2 doesn't have that. Download the web edition of Quartus. I think it has that, but to be honest, am not 100% sure.
    thnak you for the reply, i am using max plus 2 , do you think , i will be able to do it, i am doing it just for some resaon to compare between the schematic and Vhdl codes program,,,
    After synthesis, go to Tools -> RTL Viewer. It's by no means perfect(you're not going to print out nice clean schematics) but it's useful for understanding how the VHDL was interpreted. Why do you want the schematic? Documentation purposes? So you can edit it? To try and visualize the RTL? Something else?
